Can the Cigarette Lighter only be "hot" when the car is on?
Old Mar 20, 2012 | 05:17 PM
DashingDaryl's Avatar
Default Can the Cigarette Lighter only be "hot" when the car is on?
The CD player in my car went out so I started using my ipod via a FM transmitter. When I shut off the car, I also have to unplug the ipod and transmitter. Is there anyway I can change the Cig plug/Accessory plug to only be hot when the engine is on?
A Mercedes I had let you switch a fuse from spot one to spot two to accomplish this.
Anyone know if the Camaro has something similar?
Old Mar 20, 2012 | 05:26 PM
castorino's Avatar
You can probably tap into the remote wire going to the radio.
Old Mar 20, 2012 | 06:54 PM
^^^ yep you would need to tap into a switched wire.
Old Mar 20, 2012 | 07:02 PM
Lighters can pull a lot of amp so be carful where you pull from. There is no simple way switch which side of the fusebox power is pulled form.
Old Mar 20, 2012 | 08:08 PM
Excellent. So I could go to an auto parts store and buy an aux power outlet; then wire it to a switched power supply, therefore keeping my wiring harness in tact.
Old Mar 20, 2012 | 10:12 PM
make sure to put a fuse in the line as close to the hot side as you can
/M3
May 31, 2023 07:22 PM
AmericanMuscle1989
Jun 25, 2013 10:38 AM
J.McC
Apr 15, 2013 12:23 AM
02camaro02
Jan 3, 2007 12:32 AM
