Can anyone identify this part please.
![Name: maro.jpg
Size: 21.2 KB](https://camaroforums.com/forum/attachments/93-02-general-41/30500d1501314093-can-anyone-identify-part-please-maro.jpg)
Can anyone please tell me what that rod is that is circled in red? I was changing brakes and rotors earlier and noticed that rod or whatever it is was almost broke in half. I need to replace it but don't know what it would be called. Thanks
BTW this is a pic from the net, but thats what it looks like on my 94 3.4
ok..after what you've told me I've just realized I have a major problem! It's not the sway bar end link...its the sway bar itself that is broke... it's broke right before the end link. wow that sucks!
You can find them in wrecking yards for just a few bucks. If you have a local pick-n-pull head over there for a scavenger hunt.
Measure your's before you go and make sure you get one the same diameter.
Sounds like your sway bar rusted through. It's a hollow tube that is pinched flat at the ends. There's a vent hole punched into the tube at each end and water can enter there. As Grandpas says, pull one from a similar year Camaro or Firebird at a local salvage yard. The parts book seems to show that the same parts were used from 93-2002 but you do need to know whether or not your car has HD suspension.
yup! no suprise its broke.. mine broke at the end also... its that g** damn rap music that breaks em...
haha on a serious note, mine is a v6 chassis and i discovered it was broke when i took it out with da crossmember
ok I just finished the passenger side brakes and notice that the sway bar is snapped completely at the end link on that side, and I pulled on the end link and it just came right out. So my sway bar is useless. Time to find one at a junk yard I guess.
