Camaro ticking sound
Old 01-01-2013 | 03:33 PM
PatrickM's Avatar
Default Camaro ticking sound
I have a 1999 Camaro engine and it has a motor out of a 99 Buick with just about 100K on it. Lately it has been making a ticking sound after it warms up. It is only there until I go over 10 mph and I can't hear it. It ticks faster when I put the car in reverse. Also it sounds louder towards the bottom of the motor, any help would be greatly appreciated. Thanks
Old 01-01-2013 | 04:21 PM
Ticking sound: noisy lifters or an exhaust leak between the manifold & head or at the manifold to header pipe donut.
An exhaust leak like that can fool someone into thinking it's a lifter/engine noise.
A lower engine noise would be a knock, not a tick.
Old 01-01-2013 | 07:12 PM
PatrickM's Avatar
The link is to a video that i tried recording:
https://www.youtube.com/watch?v=XvHbZ6p1nsU
Old 01-01-2013 | 07:56 PM
Wow, that sounds more like a whack than a tick.
I'd try removing the serpentine belt and then running the engine for a moment, to see if it's a belt driven accessory (or not) making the noise.
And if the sound goes away, start fiddling with all the pulleys by hand to see if one turns stiff, wobbly, noisy, or weird in any way.
Old 01-02-2013 | 05:57 PM
PatrickM's Avatar
Alright i took off my serpentine belt and let it run for 15 minutes to warm up and heard no sound. I then put it back on and let it run for another 20 minutes and heard nothing. I drove it around then and after 2 miles i heard that sound again!!
Old 01-02-2013 | 08:38 PM
You ran the motor for 15 minutes without a waterpump? I am very surpised you did not lock up the motor and would not be surpised at all if you damaged the head gaskets. You understand what the word "moment" means? Anything over a minute is risky.
Start looking for a new engine.
In the mean time use a hard object like a long screw driver or a broom stick and set it on all the things the belt turns one by one. Put your ear against the the object. The knocking noise will me much louder in the item causing the issues. Once you have done all the other items then do the block itself and each head. The loudest spot is the winner.
Old 01-03-2013 | 01:23 PM
PatrickM's Avatar
Alright after trying to find it with my deaf ear, And stripping the oil plug(thanks to valvoline for tightening the **** out of it) I brought it in to get my oil changed and it turned out to be an exhaust manifold. Thanks for the help
Old 01-03-2013 | 01:46 PM
BasicConcepts's Avatar
Technical User
you got lucky on that one, i thought for sure that was rod knock in the video.
Old 01-03-2013 | 02:34 PM
PatrickM's Avatar
Ya that's what my neighbor said as well. I was worried for a bit because that's what happened to my last motor, but thankfully that wasn't the case
Old 01-04-2013 | 01:10 AM
wayne242's Avatar
Honestly a exhaust leak? What was the exhaust unbolted and hitting the car.. I just cant see a exhaust leak sounding like that at idle unless a pipe was undone.
