Camaro auction in my country
there are 2 Camaros in my country for sell in auction.
both red and both have Europe side mirrors that moves one 1994 V6 T roof and 1996 V6 hard top. what do u think I should buy? and beside what engines on those cars, I mean used on any other cars in case i wana buy spare parts. Lumina and ,,,,,,? In my Z28 1994 I ask for caprice lt1 parts. the 1996 v6 has rear disc brakes? what u guys recommend me to buy ? the main differance i think of that 96 has obd 2 and the accessory output that all I know as differance! may u help me! and beside do u think that a clean z28 worth both of those v6 Europe edition?? |
if you can live without t tops or if your car has t tops then go with the 96, diagnosing problems would be easier, any pics? what are the mileage on each of them? hows the body condition? floorpans rusted? do you know if they run or not? depending if they have same mileage or if the 96 has less miles then go with the 96. If you get it cheap enough, then buy em both so you`ll have a parts car in case of an accident because it seems there arent too many where you are located.
brain storming guys and random sentences may help.
The '96 V6 might have disc brakes for the rear if it was an RS model. I'm not sure if it was available any other way, but somebody else on the board might be able to help with that. My base '96 came with the typical drums in the back.
As for which one to get, I suppose it comes down to mileage and condition, and if you want a 3.4 (1994) or the 3.8 (1996). Good luck on whatever decision you make. |
Originally Posted by RedKnight
(Post 631080)
As for which one to get, I suppose it comes down to mileage and condition, and if you want a 3.4 (1994) or the 3.8 (1996). Good luck on whatever decision you make. if the car is 1994 v6 it's 3.4 this engine used on any other cars? and if it's 1996 v6 it had to be 3.8? what is RS? and what cars used that engine? I remember that the 1996 had rear drums. so it's 3.4? is this lumina engine? |
3 Attachment(s)
This the 1996 I captured 2day has rear drums, as I saw and her is the VIN code and decode it, 4th Gen F-Body VIN Breakdown
Attachment 19250 Attachment 19251 Attachment 19252 both cars has more than 250K KM. and this one has 3.8 HP motor, what other cars used that motor? cues I wanna know the availability of those spare parts for such engine. |
1 Attachment(s)
here is the VIN of the 1994 T-roof.
Attachment 19249 it has 3.4L V6 (L32) (1993-1995). and I pushed in the A/C fer-ion valve and a gas came out after all years :-D |
guys hit me with random Ideas this is the first time In my life I see V6 camaro!
by the way I looked under the 1996 and I saw there is no catalytic converter! they did that to make the car with sound loud sound? the L36 engine is used in the 2002 V6? |
Here's a decent link about the Series 2 and 3 GM 3800 engines. You have to scroll down a bit to get to the info pertaining to the L36 and L67.
Buick V6 engine - Wikipedia, the free encyclopedia I hope that helps out. |
the 3.8 L motor used on v6 from 1996-2002? just like the lt1 used from 1993-2007?
