Calipers
Old Apr 10, 2014 | 10:05 AM
93 camaro's Avatar
Default Calipers
I have a 93 chevy camaro z28. The caliper is going over the brake pads to tightly, I need to buy new rotors but the rotors are not the cause of my calipers compressing the pads too tightly. The piston is compressed squarely and as far it can go, was wondering if I adjust the adjusting lever if that would help the situation or if its even possible, let alone if it will help considering adjusting it is mostly for the parking brake.
Trying to find some extra troubleshooting ideas that might help.
Old Apr 10, 2014 | 12:01 PM
libertyforall1776's Avatar
Have you ensured your caliper slides are not worn and they are full lubed with caliper grease and slide smoothly first?
Have you flushed your brake fluid recently? What color is your brake fluid? This could be an indicator of the need to bleed/flush the brake lines.
Old Apr 10, 2014 | 12:03 PM
in the back you need to adjust the e brake out
Old Apr 11, 2014 | 07:51 PM
I am a little confused. When you install your new pads and rotors you will need to back off the park brake but if you are having issue taking the back brakes a part or you think the pads are currently pushing on the rotors too hard that indicates a bad caliper or brake line.
jrsmith4816
Oct 11, 2012 08:36 PM
AMP3D
Jun 17, 2011 09:52 PM
Amy Z28
82-92 V8 Tech
Dec 1, 2009 11:17 PM
Tonylig928
May 11, 2009 12:29 PM
95 CamaroZ28
Apr 4, 2006 04:00 PM
