A/c question
A/c question
Here it is...
98 3.8 i believe needs to be recharged. No air blows out through the dashboard. Will the happen becaues the system isnt charged or am i going to have the dash removed? Any help would be great.
Thanks for all the help fellas, it blows out air, and i can feel under the dash when i turn it to only the top vents the pressure builds, but still only blows at the floorboard. I hear the motor when i turn it to on, and i know the motor is good i guess
First thing I'd check is the vacuum *source* to the control switch. This is in the engine compartment near the hood support strut. If the vacuum doesn't reach the control switch the system will default to safety mode and that means air out the defroster duct. Here's the vacuum connection on a 95.
