A/C Question..
Old Apr 12, 2008 | 02:48 PM
rpope904's Avatar
Default A/C Question..
I have a quick question, I have a 95 camaro, v6.. The A/C works, but doesn't blow through the vents, it either comes from the defrost, or the floor vents.. I have been told it's probably a vacuum hose off, but i've looked and been unable to locate it.. Can someone tell me where it should be at?
Old Apr 13, 2008 | 09:02 AM
genvoodoo's Avatar
Default RE: A/C Question..
I would check behind the heater switches or maybe on the box containing the heater core. There is some disassembly to get the heater switches out. good luck.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
