A/C
Old Aug 7, 2008 | 09:31 PM
Z28Reggie's Avatar
Default A/C
Ok guys i have no idea what i am doing when it comes to the a/c compressor. I notice my a/c was not blowing cold anymore and got some of the stuff to recharger it. I know how to do this i have done that part many times. But it said the compressor was full. I cut the ac on and then notice the compressor was not coming on. Any idea how to fix or know for sure that this is the real problem. Thanks
Old Aug 7, 2008 | 10:28 PM
02StanGT's Avatar
Default RE: A/C
There is a low pressure switch in the low pressure side that's supposed to cut off the compressor if you don't have enough refrigerant. Sometimes this faults and won't the compressor work normally. If you have enough refrigerant, I would suspect that.
Old Aug 8, 2008 | 08:33 AM
Z28Reggie's Avatar
Default RE: A/C
Ok thanks man I will check that out
