A built in sauna?
Old Apr 24, 2008 | 06:48 PM
  #21
95slvrZ28's Avatar
Default RE: A built in sauna?
Thank you 95camz28, you're continuing on your path to getting banned with constant post whoring. just saving you some embarassment bro CT. You're walking a fine line, I would suggest you shape up or you'll be forced to leave.
Baseballer, the fans don't turn on until the guage starts to get towards the red part of the guage.
Old Apr 24, 2008 | 08:33 PM
  #22
Spartan66's Avatar
LT1RUNNER: I didnt mean the thermo i forgot a period in there. My cooling system basically was disconnected so my car would run hot until the fans came on or i hit high speeds. I believe the previous owner wanted the car to be like a stock nascar... He leaned it out took the cat out and took the engine out for some reason and didnt hook the cooling system back up. The 1st guy i had look at it had to put new hoses in there to get it flowing again. It took forever to get heat so my windshield fogged up easily (and it was winter).
Old Apr 25, 2008 | 11:27 AM
  #23
LT1RUNNER's Avatar
Spartan you lost me again! How was that your cooling system was "disconnected"? (whispering) dude lay off the chronic or at least share. Just giving you a hard time bro!!
Old Apr 25, 2008 | 11:40 AM
  #24
Spartan66's Avatar
alright heres what the mechanics report said from when i had my cooling system fixed. "Customer states car runs hot and overheats. Found water pump bearing failed. Found Leaks at heater core. Recommend rebuilding cooling system R&R/Replace heater core R&R/water pump, thermostat, belt, both radiator hoses and radiator cap" and it goes on to spark plugs n wires and the opti. The leaks i believe at the heater core were due to poor mechanic work done by the previous owner or something.
Old Apr 25, 2008 | 05:57 PM
  #25
LT1RUNNER's Avatar
Damn you sure do put a lot of $$$ into your car!! Did the previous owner beat the hell out of it??
Old Apr 26, 2008 | 12:07 AM
  #26
Spartan66's Avatar
Like Micheal Vic beat his dogs.... When my mechanic looked at it he told me there was alot of silicone on the engine.
1bad96z
Jan 18, 2011 09:44 PM
Posi
Apr 27, 2009 01:50 AM
Lookingformydadscar
Dec 15, 2008 06:31 PM
Lookingformydadscar
67-69 V8 Tech
Dec 3, 2008 06:57 PM
