Brake Light on
Old Jul 17, 2012 | 07:12 AM
jrsmith4816's Avatar
Default Brake Light on
Hi everyone, when I got out of work this weekend, I pulled my e brake and noticed my light would not go off. Been two days no and it stays on while driving with no brake engaged. any ideas on what this may be?
Also, it feels like the cable it loose or getting stuck on something because every time I go to engage it, there is different tension with it.
Old Jul 17, 2012 | 08:29 AM
jkeaton's Avatar
you mean the light on the dash or the brake lights at the rear of the car? There is a switch inside the console, you might check that. Mine was not making good contact making the dash brake light stay on all the time. I had to clran the contacts with some sandpaper. It's a simple metallic switch that is prone to corrosion.
Old Jul 17, 2012 | 12:08 PM
The light on my gauge cluster. It usually comes on when the parking brake is engaged, but now it just stays on all the time
Old Jul 17, 2012 | 12:44 PM
either you have a problem with your brakes or the switch on the e brake is stuck. check the brake fluid level to see if its low.
Socom
Nov 9, 2013 01:41 PM
hpd218
Aug 24, 2010 12:05 PM
MegzZ28
Nov 27, 2007 01:47 PM
Skiwee10
Aug 31, 2006 12:54 AM
The_Shadow
Dec 2, 2005 07:59 PM
