Brake bolts.
Old Apr 4, 2011 | 07:31 PM
3800camaro's Avatar
Default Brake bolts.
Does anyone know the part number for the bolts that mount the caliper beaker to the diff? It's a rear end out of a 98 z. Are they the same as the 95-97 bolts? The only part number I can find is 10229606 and that's for the 95-97.
Old Apr 5, 2011 | 01:00 AM
thats what im showing in my 93 book. call your local gm dealer and ask the parts guy what number it is and what the price is.
Old Apr 5, 2011 | 07:29 AM
3800camaro's Avatar
The gm dealer isn't even sure. He thinks it's the same bolt. I'll have to give it a try I guess. To bad it's going to take two weeks before they arive.
Old Apr 5, 2011 | 10:39 AM
Massey's Avatar
Is your parking brake part of the caliper or is it a pair of shoes inside the rotor?
If the caliper is part of the P-brake then you have the right part #
If the P-brake is shoes in the rotor then your Pin kit (which comes with bolts) is H5075 from your favorite part store.
For the older Rear disk hardware I am showing H5031 (Raybestos) or this for wagner
Wagner F126897S - Brake Guide Pin | O'Reilly Auto Parts
Hope this helps
Massey
Old Apr 5, 2011 | 10:47 AM
3800camaro's Avatar
Its the newer set up. So it should be the same setup as your camaros. It's got the one peice horse shoe style p brake pads. If only there was an o'reillys in Canada.
Old Apr 5, 2011 | 10:49 AM
3800camaro's Avatar
P brake in the rotor.
Old Apr 5, 2011 | 12:43 PM
Massey's Avatar
Then the pin and bolt kit you need is the H5075 Raybestos part #. Most brake manufacturers use raybestos numbers so you should be able to find your pins and bolts at your favorite part supplier. You will need 2 kits since they only cover one side. Around here they are like $6.00 each so it wont break the bank.
Massey
Old Apr 5, 2011 | 01:06 PM
3800camaro's Avatar
Thanks. I'll have to see if I can find the kit.
Old Apr 5, 2011 | 03:13 PM
3800camaro's Avatar
Wow Massey your good on price. It's cheaper for me to get the kit then to go to gm. Kinda sad how gm screws your over for everything.
Old Apr 5, 2011 | 03:55 PM
Massey's Avatar
I just bought a set for my car that is how I know the price. I am going to be doing brakes on all 4 corners of my car here soon so I have been collecting the parts. Check out my build log (linky in my sig) to see what I have done to the rotors.
Massey
