Body, not mechanical question
it's time to strip down the 4th gen and repaint but it has a lot of plastic
does anyone want to share some tips of getting the mulitple coats of paint off and down to bare plastic so i can prime and then paint?
Metal isn't bad because high build primer takes care of that but I don't want to risk grinding away plastic
how do vette guys/gals do it?
"Vette guys", such as myself, tend to have the car media blasted. I deal with (fix/restore) older C3 Vettes, and the glass on these do not have a sealed or gelcoat surface, so using paint stripper that can permeate the glass and potentially ruin a new paint job is a bad idea. And you definitely don't want to sand all the paint off for fear of gouging, not to mention the time it takes (forever). Scraping is out. The plastic panels on your car is a different animal though, and there are strippers that are made to not harm plastic. Be careful with your urethane bumper covers though, those can be more temperamental. Are you trying to do this on the cheap? Blasting means you pay someone else to do it unless you have the equipment, but I still prefer it over using chemicals.
I'm not going to spring for the blasting. I'll "ask Sherwin Williams" when i'm there getting the base/clear. Maybe they have a magic elixir I can use for the urethane bumpers. I'm going with a guy who gets a 30% discount so I'll get it while I'm there if they have something. I don't want to have to revisit it again for many years so the prep work I fear is going to take quite a while.
Have you ever used the scotch bright pads for stripping paint by 3M? I seem to have a lot more control with these pads then with any other type of sanding process. I think you could still damage the plastic if you not carful, maybe set your beer down and use two hand,,, I know, I know it was tuff for me too but it might be worth it.
Strip Disc System Backing Pad And 3 Discs
The process is not optimal but if you chipmunk half the can and take small swallow it is not to bad and the weekend or evening can progress as planned.
The bumpers and plastic panels/roof I understand need a bit of TLC and I don't want to have divots in them
klong2194
Dec 28, 2011 08:36 PM
