blinker fuse blowing
Blinker fuse keeps popping on my 97... Anyone aware of a common spot that blinker wires short out? Assuming that is my problem since it does not blow until using the blinkers and my hazards work fine.
Thanks for your help
found that as soon as i put it in reverse the fuse pops. took the bulbs out to see if they were causing it but still poppping with no bulbs. common spot that this system shorts out? link for a wiring diagram? any help would be great. thanks again
is this a manual or auto, there is wiring in the center console on the auto. look at number 44 and 46 here 4th Gen LT1 F-Body Tech Aids
