Black rims post!!
OK 1.25" spacer? How do you plan on actually attaching the wheel to the car? You wont have any studs left to thread a lug nut on. When a buddy of mine put actual Corvette wheels on his car we needed a 1/4" spacer and they were 18x9.5 with the offset for the Corvette not the proper offset for the Camaro. I bought the 17 x 9.5 offset for the Camaro for 2 reasons. 1st they will fit front or rear with out rubbing and second the rubber is a whole lot cheaper for the same tire in the 17" variety.
I cant see the wheels you want here at work my proxy blocks the site. If you get the wheels with the proper offset then no spacers should be needed. I did on both my V6 and Z28 have to bend a pinch weld in the inner wheel well a little for safety and a little more clearance.
Massey
Massey
