Battery problems...
Old Feb 4, 2012 | 10:32 PM
BillsFan727's Avatar
Default Battery problems...
So i've been working a lot and haven't really been able to work on my car, but i've installed a new yellow top batter along with a new alternator because the battery was in horrible condition and the alternator was shot. Now i have something draining my battery... what are some common cases with a 1994 z28? Where should i start looking for this drain?
oh and i also need a front dash. where is a good and trusted place to buy these?
Old Feb 5, 2012 | 06:28 AM
one common cause of battery drain is center console light does not go off when closed. check and make sure the exciter (small) wire to the alternator is not getting power when the key is turned off. i have used ebabe for a dash pad woh this one is dark gray, may have to get it myself 93-96 Camaro Z28 RS SS Dash Pad Cover GM OEM NEW | eBay
ricks has em
Camaro Dash Products for 1967-2011 Camaro from Rick's Camaros for '1993 CHEVROLET CAMARO' - Rick's Camaro Parts
Old Feb 5, 2012 | 07:12 AM
androzer's Avatar
disconnect all extra equipment like Alarm, check if u have radio!
any other equipment connected to the car might drain your battery.
Old Feb 6, 2012 | 11:24 AM
ricks has em
Alright ill check it out when i get off work thanks
libertyforall1776
Feb 24, 2014 02:11 PM
DOC'S Z28
Apr 17, 2010 08:52 AM
typeomang
Feb 9, 2009 10:30 AM
bowtieguy
Jan 5, 2009 10:44 PM
trailerparktrash2009
Sep 22, 2006 07:53 AM
