axle shaft
Old May 21, 2011 | 06:46 PM
nickb123's Avatar
Default axle shaft
Today i replaced the rear brakes on my car and i noticed the rotor on the driver side was warped. But it was really the axle shaft. when the wheels on i spin the wheel and it woobles about 1/8-1/4 inch side to side. Im sure it happened when i let a friend drive it and he spin out hitting a curd and braking the wheel. I checked to see if it was bent but i guess i didnt look good enough. My questions are, how hard is it to pull out the axle shaft because at a local salave yard they will sell one from a 95 camaro of $10 if i pull it. Other wise it looks like about $65 for a used one off ebay. will one from a 95 camaro even fit my 98? there both v6's with out tcs.
Thanks
Old May 21, 2011 | 07:21 PM
nickb123's Avatar
another question, would it be ok if i reassambled the breaks on the bent side with the new parts intell i can buy a new shaft?
Old May 22, 2011 | 02:53 AM
yes it will fit. they are not that hard to r&r.
Old May 22, 2011 | 04:32 AM
BasicConcepts's Avatar
Technical User
all you need to do is pull off all the brake stuff, the diff cover and pull out the clip that holds the axle in place then you just slide out the axle and slide in the new one dont forget to put the clip back in bolt up the cover and the brakes and go have fun... also new fluid and a new gasket
Old May 22, 2011 | 08:21 PM
nickb123's Avatar
alright. Im going to a junk yard sometime this week to pull one out for $10. i will ask if i have any problems. but in the mean while, is if bad to drive with it bend?
Old May 22, 2011 | 08:33 PM
Technical User
i wouldnt for one think if it breaks your screwed second you could damage the differential
Old May 22, 2011 | 09:12 PM
nickb123's Avatar
Break the axle shaft off the 95? How?
Old May 22, 2011 | 09:15 PM
Technical User
no your axle shaft
Old May 22, 2011 | 11:37 PM
I'd also think twice about letting your "friend" drive the car again.
I wonder what else he did to the car that didn't leave any obvious evidence?
Old May 23, 2011 | 06:51 AM
nickb123's Avatar
Ya it seems like every time I let some one borrow it something happens, like when I let my dad drive it he seized the engine.
