Automatic transmission fluid and filter change
Old 03-30-2011 | 12:34 AM
tjsmar's Avatar
yeah i can see how that makes some sense. How about any specific brand? and additives? anything special i should look into getting?
Old 03-30-2011 | 01:34 PM
AF1's Avatar
AF1
Default Also
When you pull the filter, a new filter seal should come in the kit with the new filter. The old seal is a pain in the *** to get out; just take your time with a small screwdriver....don't tear up the shaft it goes into. Getting it back in is a pain also. I had a guy at work machine a piece of aluminum as a tapping block for my but you can use a socket and small hammer to tap it up into place.
Just take your time.
Old 03-30-2011 | 08:53 PM
elyk10's Avatar
Originally Posted by torque_is_good
just so you know, the tranny holds about 12 quarts of fluid. When you drain via the pan you will maybe get about 4-5 quarts. Yes, that's better than nothing. if your fluid is brownish then it would be best to flush the transmission and get rid of all 12 quarts.
This. I've made this mistake, except I put 5 quarts in a dry transmission
Old 03-30-2011 | 11:06 PM
claude1991's Avatar
Anything except the cheapo house brand. My old car started slipping after adding the Advance brand fluid (or I should say it slipped once, after driving it for 8 hours straight, only bathroom breaks) fixed it by putting back in name brand fluid.
High mileage fluids are slightly thicker, and because of that, could I guess give you worse fuel economy (theoretically)? But tit would be better for the transmission, and if you lost any fuel economy it would be negligible. I never noticed anything...
No special additives, most of them don't work. The Lucas stuff is like jelly, so for a really worn transmission I might put that in. But it would really just be a band-aide for the inevitable if it was that bad.
Old 03-30-2011 | 11:29 PM
tjsmar's Avatar
Ok that cleared some stuff up. Thanks for the info guys
LolVtech
03-03-2014 01:39 PM
tammybrian2
09-26-2013 09:02 PM
hawk driver
05-25-2010 05:01 PM
tedge49
01-12-2008 09:46 PM
98LS1Camaro302
01-26-2007 09:36 PM
