August Ride of the Month Vote
ok 4th gen members here are the rides representin. get involved and vote.
sandratt
Stats on my car: all stock 97 RS
Y87 package
White vert
only 74 bright purple metallic verts made in 97
Thanks again!
![Name: 03b6780f.jpg
Size: 102.9 KB](https://camaroforums.com/forum/attachments/93-02-general-41/18117d1501216045-august-ride-month-vote-03b6780f.jpg)
Dugeman
My car is a true 1993 Z-28 , it has the orig. block in it . the block is now a splayed 4 bolt, 1/2 filled , forged crank, H-beam rods diamond 15.1 pistons , total seal rings. It has Profiler Alum. SBC heads converted to LT-1 reverse flow. Comp. cams solid roller ,Msd crank trigger , Billet dual syn dist. & Digital 7 ign. , T&D shaft rockers,Manley S/S valves , Single plane F.I. intake , Wilson 1100 TB ,F.A.S.T. rails . The motor made 672HP @ 7600 As for the rest of the car , Painless wiring , th-350 w T/B , ATI 5800 converter , PST driveshaft , QA-! d/a shocks, BMR, BMI, Madman susp.. Moser 9" 4.56 pro gear , 35 spline axles ,5/8 studs Rci fuel cell ,caged and cert'ed to 8.50 . The car only has 5 runs on it , 10.42 @ 129.99 the rest were 10.50 @ 129.42-130.40 . this was testing on footbrake only. The body was modified to fit M/T 28"-10.5 Slicks & 28" Hoosier front tires, Lexan windshield and Hatch , Sunoco pin on hood. The color is 93 Cadilliac Black Cherry
sandratt
Y87 package
White vert
Thanks again!
Dugeman
![Name: 2012CamaroNewJune12010.jpg
Size: 169.1 KB](https://camaroforums.com/forum/attachments/93-02-general-41/18118d1501216045-august-ride-month-vote-2012camaronewjune12010.jpg)
Voting is now closed. Here is our August 2012 ROTM Winner. Congratulations chuckles
chuckles
1972 Camaro z28
pro built forged internals 355 cid V-8 @ est.400hp, Tremec close ratio 5-speed trans, Center Force clutch, factory posi-traction rear w/ 3.73 gears, mirror finish “Orange Crush” paint w/ black stripes and cowl hood, correct codes black bucket seat interior w/ factory console, custom Covan dash w/ full Autometer gauges, walnut steering wheel, fast ratio power steering, Wilwood 4 wheel power disc brakes, 17” Torque Thrust polished alloys, 4 link rear suspension w/ coilovers, great sounding dual exhaust, upgraded front & rear swaybars & frame connectors
chuckles
1972 Camaro z28
![Name: e0c28710.jpg
Size: 310.4 KB](https://camaroforums.com/forum/attachments/93-02-general-41/18021d1501215796-august-ride-month-vote-e0c28710.jpg)
