All the mods so far, whats left?
Old Feb 3, 2014 | 11:23 PM
Eagle564's Avatar
Default All the mods so far, whats left?
Ok so after weeks of searching I have found some info about the guy that previously owned the car and what he had done in terms of mods. Not sure whats good and bad here, hoping for alot of clarity and assistance guys.
The guy bought it in August 07' with 44,500 on the clock. All stock, SLP Build # 1775
Factory Options:
Everything! Hurst Shifter - Leather - Monsoon
Exterior Modifications:
17x9.5 and 17X11 Silver DD ZR1's
Black SLP SS Grill
Clear Corners
Titanium Letter Inserts
Whistler Mod
Interior Modifications:
Pro 5.0 shifter with C6 shift ****
Dynamat on Doors, Sail Panel, floor and back hatch
Custom Tweeter Pods
Performance:
American Racing Long Tube Headers/ORY
Magnaflow Cat-back
LS6 Intake Manifold
Ported and Polished Throttle Body
NGK IX TR-55's and MSD Wires
SLP Air Box Lid
TB Bypass
SLP Bellows
Diablo Sport Predator 3 (custom tune)
Suspension/Chassis:
Koni 4/4 (Koni Yellows)
Strano Springs
Strano Hollow Swaybars 35mm Front and 22mm Rear
UMI Adjustable Panhard Bar and Relocate Kit
Hotchkis Subframe connectors
UMI LCA's and LCA Brackets
UMI Tubular K-Member
UMI Tubular Upper Control Arms
Drilled and Slotted Rotors F/R
Drivetrain:
Pro 5.0
LS7 Clutch/LS2 Flywheel
Carbon Fiber Syncros
Motive 3.90's
Poly Urethane Tranny and Torque arm mounts
Poly Urethane Motor Mounts
UMI Adjustable Torque Arm
UMI Tranny Cross-Member
Line Lock
Electronics:
Pioneer AVH-P4900DVD
Full Infinity Kappa System
SLP Fan Switch
Line Lock
To-Do List:
Ok this is his list on a website when he was trying to sell it in July of 2013. I bought it from a dealership a few weeks back and I've had a number of minor issues I've been dealin with. But this list seems to bring back some hope that I made a good deal, especially since she's at 71K on the ODO right now. So guys, what do you think of that list? Whats good and whats bad? And lastly, what mods are left to do to bring her up to around 400-450 hp to the wheels?(Cams, heads, etc)(Preferably keepin it N/A for a few years)
Old Feb 4, 2014 | 12:50 AM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
a cam swap should get you to your goals. I would ask this question over on ls1tech. they will give suggestions,(but beware it usually will also start a cam selection war) find what cam you like. if you plan to do the swap your self prepare for at least a 3 to 4 days to the swap in the car. you will then have to get the car retuned.
looks like your car has most of the mods top the suspension I want to add eventually to my 98, the strano parts are very good from what I read and they are not cheap either.
where in Oregon are you? Ive probably seen this car on craigslist im always looking at 4th gens on there for sale
Old Feb 4, 2014 | 07:23 AM
check and make sure the dealer didn't remove some of the mods. theres some coin in her thats for sure. koni's are rebuildable so if they are getting on in years that may be something you will want to have done.
Old Feb 4, 2014 | 07:29 AM
Cheeks's Avatar
August 2011 ROTM
If 450whp is what you're after, a good set of ported 243s and any decent sized cam will get you there. The mod list sounds pretty good for now.
To hit that hp number, you'll also need more fuel pump, look into a walbro 255 and a hotwire kit for it
Old Feb 4, 2014 | 12:54 PM
Eagle564's Avatar
Im in oregon city. It had been on craigslist for like 4 months. And i probably wont do the swap myself, not a whole lot of free time or the necessary knowledge.
I dont think the dealer took anything off this car. They were not very bright. All they knew is it was a 6 speed V8, with magnaflow exhaust lol. Didnt even know it had no cats, luckily passed inspection still.
My only concern is theres a dyno sheet for 2010 in the car, showing 335hp. Not sure if this was before his mods or after. I left all the receipts at the dealer like a moron. Need to see if they still have them.
Old Feb 4, 2014 | 02:34 PM
Cheeks's Avatar
August 2011 ROTM
with that junk diablo tuner and the mods on the car now, it sounds close to being right (335whp)
Remember, a canned tune will only get you so far, at some point you're going to want to pony up the cash to have someone do a real tune using hptuners/ls1edit etc
You'd be surprised how much a cam/heads will wake a car up, especially with a 6 speed. You'll always read a little higher then the auto guys due to less drivetrain loss
fwiw my car showed 505whp with a 6 speed, no changes other then an th400/9 inch and it showed 394whp and went 2 tenths faster lol
Old Feb 4, 2014 | 03:16 PM
June 2010 ROTM
Well does Oregon city have to deq? I'm in Hillsboro and have too that's why I have a catted y pipe for my long tubes if I ever get them on. Be prepared to shell some money for a head and can swap. Last quote I got was like 5-7k to do a cam, head and tune. I'm nearly fell out of my chair. Still getting used to ls1 parts pricing in used to old small block part prices.
Old Feb 4, 2014 | 04:04 PM
Eagle564's Avatar
Ya i didnt think that tune was all that great from what ive read. How much usually for a professional tune?
And camaroboy, i have to deq, they didnt use the sniffer though and my car wasnt throwing codes so it passed somehow. I wasnt expecting that much for a heads and cam lol damn.
Old Feb 4, 2014 | 04:26 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I paid around 400 for a dyno tune for mine, but expect more if the shop does dyno and street/drivability tuning. Heads and cam can be installed by yourself in a few hours without dropping the motor. Parts should run around 3 grand ish
Old Feb 4, 2014 | 05:31 PM
MKCoconuts's Avatar
I noticed tubular lower control arms for the front weren't on the list. You didn't mention whether it had a 10 bolt or the rare 12 bolt rear in it. If it's got the 10 bolt, there's something you're gonna wanna swap.
