Air injection pump question.....
Old 10-12-2011 | 04:58 PM
JackBlack95's Avatar
Default Air injection pump question.....
Anyone have a diagram of this system, been searching google for an hour. It's missing parts and 2 connectors are just hanging there. I'll post pics if that helps. Wonder why someone would remove these items, what does this system do? what effects would it have on the motor?
Old 10-12-2011 | 05:05 PM
The air pump injects air into the exhaust so the catalectic converter will burn hotter and give you better emissions. These missing parts will not hurt anything but your emission. I am getting ready to remove my whole air system because I am installing headers. What part do you need I sell them right
Old 10-12-2011 | 05:14 PM
The cat converter is most efficient once it heats up. Injecting air on a cold engine/exhaust helps to heat up the cat faster. Once the engine hits a certain temperature, the pump is switched off. It has no effect on the engine, only cold engine cat performance.
Old 10-12-2011 | 05:16 PM
Cool thanks, Guess I'll leave it. The exhaust leak kinda gets on my nerves.
Old 10-12-2011 | 08:24 PM
You should plug that.
2Z's
07-03-2014 02:38 AM
Turbolag86
01-16-2011 08:30 PM
sewerrat
11-05-2010 09:03 PM
gerod11
06-11-2010 12:28 PM
1985RS
07-11-2007 10:54 AM
