air conditioning help
Took my 94 Z28 into the shop as the compressor would not activate. They advised me that the compressor is fine but there is an electrical issue somewhere between the dashboard switch and the AC relay. They were able to " jump" the compressor to test it and all was fine. The 20a fuse is good and the relay seems to be good too. Any advice as to what else to check? Thank you
