ac problems
it seems my ac clutch coil is fine, however when i probe the plug on the compressor i get no clutch function. jumper wire my ac relay same results , this seems like a dead short, just sparks a little. wanted to charge system . basicly wanted to know if anyone else has had this problem. thanks
If you had a dead short it would just fry your fuse.
Originally Posted by jtrotter
(Post 630484)
(Post 630484)
(Post 630484)
These switchs are there to protect your compressor. No pressure in the system means no oil flow which means the compressor life in measured in seconds. With high pressure you could have liquid in the compressor in which case you will not have a second before it blows apart. Are you trying to cycle a compressor without anything in it? |
no i am not getting power to compressor, fuses fine bypassed relay , just at stand still. even bypassed low pressure switch.
