Abs issues
Old Jul 23, 2014 | 06:07 PM
v64thgen's Avatar
Default Abs issues
Found out from the shop today that the abs control module, and the abs pump and motor assembly are toast. The shop can apparently only get them from the dealer...came to $2000+ for just parts. Is this something that is doable in the driveway if I get the parts myself? The shop said the control module may need to be programmed by the dealer, is this true? Does anyone have a how to on this job? The car is a 94 3.4l.
Old Jul 23, 2014 | 08:15 PM
look for a used one. preferably from a 94 v6.
Old Jul 23, 2014 | 08:26 PM
rock auto has the parts listed
Old Jul 24, 2014 | 05:44 AM
v64thgen's Avatar
Yeah, the prices on rock auto are much better. How do I change them out? And where do I find the control module?
Old Jul 24, 2014 | 08:35 AM
Old Jul 24, 2014 | 06:39 PM
v64thgen's Avatar
Thanks for the link, but I ment where on the car.
Old Jul 26, 2014 | 05:13 PM
v64thgen's Avatar
So does anyone have a how to on how to change these abs components?
Old Jul 26, 2014 | 11:54 PM
i believe its under the driver side kick panel. silver box.
Old Jul 29, 2014 | 01:23 PM
v64thgen's Avatar
thanks, i believe i've seen it before. just didnt know what it was at the time. to change the abs pump/motor assembly would i have to drain the whole system of brake fluid first? or is there a way to change it without having to drain the system?
Old Jul 30, 2014 | 12:14 AM
we had one guy switch them, one from another car, and bleed it. it worked. i would advise you have a shop do it though. brakes are important and abs is something i have not tried to get into.
