98 won't idle
I have a 98 that won't idle to save your life. New sensors, new fuel pump, new throttle control, I can't remember what all has been done at this point. If you can get on the road the car runs like a beast. Get in town, stop at a light dead. You literally have to drive it with a foot on the gas and one on the brake. Suggestions please thank u
A clue of what engine is in it? We are going to waste a lot of time guessing stuff and you say We already did that.
I start off, EGR Valve leakage test?
I do not believe either V6 or V8 were drive by wire in 98 so what do you mean by throttle control? Last time I check your foot controlled the throttle. Did you mean the IAC motor, was the proper homeing procedure done to it after it was installed?
Was the fuel pressured tested?
How old are the plugs and wire?
If the plug where recent how do they look?
Are there any code stored in the PCM?
Do you have access to a infrared heat gun?
Don't take it personally I have had friends that are car guys and I talked with them for hours trying to talk them through an issue on the phone. Then when I gave up and went to their house I found they where doing a test wrong and giving me bad info. In many cases I figured out the issue in less then 10 minutes.
Here is my list of the things that could be wrong.
Fuel pressure (most likely a regulator issue)
EGR valve leaking a small amount of exhaust into the intake.
Failing or dirty fuel injector(s)
Dirty IAC port
A lazy/failing IAC motor
IAC motor not homed
ICM internal issue
Secondary ignition system failure. (cracked plug or a bad crimp on a wire)
Vacuum leak into a single cylinder.
Sticking valve
Stretched timing chain.
I am sure I am forgetting something.
