98 3.8 Issues
Old Dec 18, 2013 | 10:37 AM
Phirewire's Avatar
Default 98 3.8 Issues
Took it for its first drive today, and ran into a few issues. Going down the road I had a loud clicking noise (Pretty sure I got that covered) and In Park, Neutral, or it seems drive the engine won't go above 4k. Whenever I go I feel down on power and it backfires quite a bit. Only code thrown is a Mass air flow. Would this be a huge cause to both these problems? Generally MAF is cause to hard starts and stalling.
Old Dec 18, 2013 | 10:46 AM
Mass air flow sensors job is to tell the computer how much air is entering the motor. If that is not working right it will cause a drop in HP.
Old Dec 18, 2013 | 07:32 PM
Massey's Avatar
A dead MAF in that engine could cause the computer to put the engine in "Reduced Power Mode" which is enough power to get to 30-35 MPH but that is about it. It is there because the computer does not have enough info to properly tune the engine and it falls into a preprogramed map that will allow the engine to run but only enough to get to the shop or off the road.
Massey
Old Dec 21, 2013 | 07:04 PM
mfmfim's Avatar
Look at your mass flow sensor. It's easy to remove. If the wire inside is black, it needs to replaced or cleaned.
I haven't tried it but I was told carb cleaner will also clean the mass flow sensor wire.
Old Dec 21, 2013 | 09:13 PM
Do not use carb cleaner. By design carb cleaner leave behind a oily residue, this keeps the moving parts like the choke in working order and it will kill a MAF sensor. They make MAF sensor cleaner. It is basicly electrical connector cleaner that leaves no residue.
Normal dirty MAF sensors do not set MAF codes.
Old Dec 22, 2013 | 01:13 PM
mfmfim's Avatar
Thanks, I didn't know this.
WIspartan1026
Jun 19, 2012 04:28 PM
mick.mcgirr
Jan 3, 2011 11:23 AM
camarophil22
Feb 18, 2010 09:42 PM
red star
Aug 21, 2009 01:46 PM
laxloser18
Apr 28, 2007 09:06 AM
