96 3.8 AC Compressor Removal
Old Jun 7, 2014 | 11:23 AM
REN's Avatar
REN
Default 96 3.8 AC Compressor Removal
Any advice on getting the Compressor out? I see bolts in the back and they look hard to reach. Does the Alternator need removed to get to the back bolts and hoses. Or am I missing something? Thanks!
Old Jun 7, 2014 | 06:44 PM
try and download the factory service manual,,, brb ok go here and click on 96fb http://www.mediafire.com/?40mfgeoe4ctti
Old Jun 8, 2014 | 01:52 AM
fbodyrs96's Avatar
you need to get them form underneath the car.
Old Jun 9, 2014 | 07:28 AM
REN's Avatar
REN
Still struggling with this. I can get a socket on the rear bolt but not a ratchet. Cannot get open end wrench even close.
Any tips or better tool ideas. Don't want to remove entire exhaust system to access it but it's tight. I'm sure someone has had better luck.
Old Jun 9, 2014 | 08:09 AM
2Z's's Avatar
Im not too sure how close the v6 set up is to the v8 set up, but I know my gear wrenches came in handy as well as a couple different sized socket extensions. I did all the work from the bottom with the exception of the bolt that hols the lines onto the rear of the compressor. You just need to approach a job like this with patience and some logic with a little "creativity" mixed in. Good luck!
Old Jun 9, 2014 | 05:45 PM
fbodyrs96's Avatar
You need extensions, it will reach.
Old Jun 9, 2014 | 08:03 PM
I think I had to use a swivel socket on an extension but I have headers so I may have had more room.
Old Jun 13, 2014 | 09:20 PM
REN's Avatar
REN
Finally got it out. Had to use a toggle socket adapted and a swivel socket to get the rear bolt holding the hoses. The other two bolts were easier. Thanks for the tips!
Old Jun 13, 2014 | 09:54 PM
2Z's's Avatar
Being creative helps huh? LOL!!
TruSiaki
Jul 5, 2012 10:14 PM
shai one
Jul 2, 2010 09:21 PM
jeffR
Oct 28, 2009 10:11 PM
c1500
Aug 25, 2005 08:48 PM
