95 z pulls left
Old Dec 6, 2015 | 03:03 PM
95z28man's Avatar
Default 95 z pulls left
Hi all. So basically like the title says, my 95 z pulls left. I'm almost positive its done it since I got it but I can't remember for sure. I've had two alignments done and actually had a mechanic look into the issue not too long ago. They said the alignment looked fine and suspect it's a tire issue but since I have directional treads they can't completely switch the tires to see. I'm pretty sure it pulled on my last tires too though. What are some things that might cause it to pull left? Parking in the garage with my wheel completely straight, you can just barely see the front tires turned to the left ever so slightly but like I said, I've had it aligned twice and again had the alignment checked just recently. These weren't all done at the same shop either.
Old Dec 6, 2015 | 07:37 PM
tire pressure low on that side, brake drag, tie rod end or ball joint with enough play. does it pull to that side all the time or does it change
Old Dec 7, 2015 | 07:54 AM
95z28man's Avatar
It's the same all the time. Curiously I didn't think about break drag but I don't think that would be exactly the same all the time. I had the tie rods replaced some time ago and I know it pulled before then.
Old Dec 7, 2015 | 08:01 AM
jack the front up and turn both wheels and see if one is harder to turn and listen/feel for grinding or vibration. wheel bearing going south could also do it.
Old Dec 7, 2015 | 09:43 AM
Swap the tires from front to back and see if it still pulls.
Old Dec 7, 2015 | 11:26 AM
95z28man's Avatar
Front to back didn't make a difference, the shop tried that.
Old Dec 7, 2015 | 11:27 AM
95z28man's Avatar
Pretty sure the ship checked that but I'll mention it next time
Old Dec 7, 2015 | 11:28 AM
95z28man's Avatar
It's pulls to the left and there is a slight noise when turning sharply to the right at slow speeds. It's kind of a moaning noise.
Sorry for the multi posts, I'm replying on my phone :/
Old Dec 7, 2015 | 11:48 AM
your sway bar look ok, car on flat ground, is it level? stock the driver side should be 3/8-1/2 in higher. i know, weird but thats how they are. measure center of the wheel, ground to fender.
Old Dec 7, 2015 | 09:31 PM
95z28man's Avatar
Higher than what? The passenger side or the back?
