95 Camaro starting/electric issues
When I turn the key to my 95 Camaro to the on position, the dash lights/gauges, door chime don't work but everything else electrical seems to work. When I turn key to start position it doesn't turn over or make any sounds but dash lights/gauges come on. A couple times in the past month it has also turned over but not idled or ran well at all but next day started and ran fine for a while. 2 weeks later drving it and it bogged down and died when I pulled off road and started next day. Then a week later it wouldn't start but jumped it and finally started and ran fine until current problem. I'm lost! Please help! Thanks!
is this a v6 model? are you getting a check engine light? have the car scanned for trouble codes if at all possible. check fuel pressure. look for lose or damaged wires or wire connections on ignition parts like coils, modules and what you see. check battery connections and clean the battery cables and battery terminals. wire brush the heck outa them. may have to scrape with sharp object if you have a carbon coating on them. also check your junction box wire ends to make sure they are clean and not damaged. they are on the passenger side fender well, positive box is red with a cover, negative is open and a bit further away from battery on the fenderwell. also check to make sure the battery ground wire is getting good connection at the engine.
I have checked the basics and they all seem fine. I've noticed when I manipulate the key so that the dash bulb check, gauges and chime all function properly and I turn key to start and engine turns over it will start and continue running as long as I can keep the key in the right spot. Soon as key moves a hair, engine dies.
Is checking the ignition switch or bypassing the VATS easier to do? I'm planning on bypassing the VATS anyway.
I don't think your problem is with the VATS system in the key switch upper column. The actual ignition switch electrical contacts are located at the base of the column.
