95 3.4.. what gives
Old Feb 9, 2012 | 06:58 PM
iLL95's Avatar
I Like to Party
Super Member
Default 95 3.4..troubles
Ive put every mod (at least bolt on)that I had the money for, Ive replaced,
New fuel pump
New Fuel filter
Recent Oil change
Spark plugs/ wires
New IAC
New K&N intake
New exhaust
New Headers
New Battery
New Starter
New Gaskets
It still runs rough! Since day one when I bought it, I restored it to what it is now, and I just want it to perform that way. I seafoamed it already (about a month ago) but havent driven it on the road, just ran it. Is it normal that there's still some white smoke coming from the back? I started her up tonight after letting her sit a week (due to school) and theres the white smoke.. will it just take time to disperse from the engine? Im taking it to the shop tomorrow because he does free diagnoses, my main concern is the rough idle, it doesnt so much as shake anymore but the exhaust sounds more rapid, any thoughts?
Old Feb 9, 2012 | 07:01 PM
BasicConcepts's Avatar
Technical User
are you sure the "smoke" isnt steam? when its cold out water condenses in the exhaust than heats, boils, and steams
as for the rough idle hows it when you drive? any codes?
Old Feb 9, 2012 | 11:31 PM
Not to be a pessimist, but rough running and white smoke from the exhaust can be an indication of coolant getting into the combustion chamber. May want to do a compression test before throwing more parts at the problem.
Old Feb 10, 2012 | 02:08 AM
Spatfieya's Avatar
This.
Coolant in the combustion chamber will definitely cause your idle to be rough.
Old Feb 10, 2012 | 02:29 AM
JGuy07's Avatar
Come on Ill, you've been on the forum long enough to know that the white smoke should've got your attention. And you probably should know how to check it out...you slippin? lol
Old Feb 11, 2012 | 10:35 PM
iLL95's Avatar
I Like to Party
Super Member
LMAO I thought you were asking if I was "sippin" ha, nah I just thought the smoke was reminent of the Seafoam that was put in it. Looks like a headgasket change is in the near future.
Old Feb 12, 2012 | 11:36 PM
iLL95's Avatar
I Like to Party
Super Member
Figured by now it's the lower intake manifolds because there is no coolant inside the oil but the coolant seems to be disappearing, Im going to be doing some tests tomorrow, luckily I already have all of the gaskets
