94 z28 cutting out when u rev in idle
Old 12-27-2014 | 02:30 PM
hardcore's Avatar
Default 94 z28 cutting out when u rev in idle
Need help new to site my z28 lt1 is cutting out for a sec when I rev gas r full throttle in park are gear as soon as u rev full throttle it cuts out r Boggs out done checked fuel psi and injectors new wires and plugs MSD opti don't no what it can be if I rev slow to 2500 rpm then stomp it will rev OK but from idle it cuts out for sec then stutters then picks up need all help I can get car was tuned by Solomon its a 383 306 cam Afr heads thank u
Old 12-27-2014 | 03:56 PM
hardcore's Avatar
Is there someone that can help???
Old 12-27-2014 | 05:54 PM
test your throttle position sensor. have a look at the maf make sure its not dirty. if it is clean with maf cleaner.
Old 12-27-2014 | 05:58 PM
here is a link to set your tps similar to testing, you want to make sure voltage rises and lowers steady without jumping. https://camaroforums.com/forum/93-02...-sensor-70605/
Old 12-27-2014 | 06:50 PM
hardcore's Avatar
Yeah thank u for info I changed tps already and drill slotted holes and set at .65 and changed and cleaned maf there was a post I seen on here awhile back in 2010 by toruqe is good he had same symptoms but it didn't say if he fixed it thanks
Old 12-27-2014 | 09:19 PM
look for vacuum leak
Old 12-27-2014 | 10:17 PM
hardcore's Avatar
I have every where man even changed intake gaskets
Old 12-27-2014 | 10:22 PM
hardcore's Avatar
I thought I had internal vac leak so I replaced intake gaskets and sprayed crab cleaner everywhere!!
Old 12-27-2014 | 10:35 PM
hardcore's Avatar
Do u no what might of happens to torque is good symptoms how he fixed it??? Just asking lol
Old 12-28-2014 | 01:31 AM
Have you checked the intake elbow from MAF to throttle valve for leaks or cracks. Was the PCM tuned to handle the 383?
