94 Z28 air/fuel ratio
Old Jun 6, 2012 | 09:26 AM
1994 Z28's Avatar
Default 94 Z28 air/fuel ratio
Does anyone know how to adjust the air/fuel ratio on a 94 Z28?
Thank you.
Old Jun 6, 2012 | 09:27 AM
You need to reprogram the PCM
Old Jun 6, 2012 | 09:38 AM
1994 Z28's Avatar
Would a PCMforless tune help? My car is running rich, that's why I'm posting. Ok here's is what's happening to my car. On start up I have to pump the gas petal while I am cranking and it take about maybe 10 secs to start. And if I dont pump the pedal and crank it it will just crank forever.
Old Jun 6, 2012 | 03:21 PM
1994 Z28's Avatar
Would a PCMforless tune help? Ok here's is what's happening to my car. On start up I have to pump the gas petal while I am cranking and it takes about maybe 10 secs to start. And if I dont pump the pedal and crank it it will just crank forever.
Can someone please help me.
Thank you.
Old Jun 6, 2012 | 05:38 PM
You do not need a tune, you need to find out what is causing the problem. I suspect you may have a leaky injector allowing fuel into the engine when it is shut off. Any amount of tuning is not goig to fix the problem. Start with a fuel pressure test and see if the pressure is holding when the engine is off.
Old Jun 7, 2012 | 07:24 AM
1994 Z28's Avatar
Ok thanks. I'm going to do a fuel system pressure test and see what I find out.
Thanks again z28pete
Old Jun 9, 2012 | 07:27 AM
with the mods you have its needs to be tuned. solomon is the best i have come across. LT1 PCM Tuning - OBDI/OBDII PCM Tuning/Programming Service what injectors are you using? what tb? mine was way rich and would not idle well till i got it tuned.
pingmister
Jul 23, 2011 09:54 PM
freaky
82-92 V8 Tech
Oct 26, 2010 08:43 PM
JeepCoMJ
May 25, 2008 11:24 PM
jdubs1813
Apr 27, 2007 02:50 AM
psycledad
Feb 26, 2007 07:05 PM
