94 Camaro starts running rough after warm up
Ok so I found out my dad has a Actron Code Scanner CP9001. We checked his 2 cars with it and was working fine. Plugged it into the camaro and the check engine light wouldn't flash at all. No code 12 or anything. The code book said to check my owners manual and look at "diagnostic circuit check".. I dont have the manual. Any ideas how to fix this. I still have the scanner with me so I can check anytime.
On the box for the scanner it says it is compatible with a 94 Camaro 3.4L, and 5.7L.. I read somewhere I need an OBD1 scan tool with an OBD2 cable. Is that correct.. Also I have an ignition interlock in the car could that be blocking the read.. Or can 94's just absolutely not do flash codes?
try some trans shops alot of the time theyll scan it for free or really cheap (thats what i did in NY cost me 10$ per scan, not to bad in my opinion)
#20
Aight so I just got to find someone with an OBD1 scanner with readings not flash codes. Appreciate it. Out of curosity why can't the 94 flash? Is the 94 just like inbetween the obd1 and 2 switch out? I'm learning this as I go. Never done this before.
