'94 a/c compressor question
Old Aug 20, 2007 | 10:10 AM
supra001's Avatar
Default '94 a/c compressor question
Hi, I have a '94 camaro v-6 that still runs great, the only problem I have is the a/c only holds a charge about 4 weeks, then starts to blow warm again. I have the dye check charge in it and it seems to be coming out from around the clutch area of the compressor. Is there a packing or o-ring on the front area of the pump that can be replaced? Can it be replaced while still being in placeon the motor? Thanks
Old Aug 20, 2007 | 12:26 PM
genvoodoo's Avatar
Default RE: '94 a/c compressor question
I doubt it considering that the engine bay is tight with all the stuff in there. You would have to take it off and service it. That is if they offer a rebuild kit for it. On a last resort kind of thing , I just took my compressor off with the rest of the AC if you want to work out something for parts.
Old Aug 20, 2007 | 12:47 PM
supra001's Avatar
genvoodoo, is your take off compressor compatible with my '94? Dumb question but I have to ask, was it working when you removed it? And lastly, what would you want for the compressor? Thanks
Old Aug 20, 2007 | 10:27 PM
genvoodoo's Avatar
The compressor came off my 94 camaro with the 3.4L It was still pressurized when removed and spins freely. As far a reimbursement...Throw an offer at me plus shipping and as long as its not like $5 you are welcome to it.
txchevyguy
Aug 12, 2012 06:04 PM
v8xj
Jul 25, 2012 01:52 PM
Murda99v6
Nov 23, 2010 06:05 PM
bond67
Aug 19, 2008 08:29 PM
