93 Waring Diagram
Old Nov 22, 2012 | 02:21 PM
Default 93 Waring Diagram
Is there any online wiring diagrams for a 93. I am looking more for routings and connection info. I am working on a car I did not take a part. I have the GM manual but I have not found a many good picture of the harness routings.
Old Nov 22, 2012 | 02:45 PM
so what area are we talking about waring against.
Old Nov 22, 2012 | 05:15 PM
It is going to be the illiterates vs. the literates. Pretty easy to see which side I am on.
Old Nov 22, 2012 | 05:37 PM
i have seen some routing diagrams in the component location views, in the 8 a section and some in other sections too, sorta scattered
Old Nov 22, 2012 | 07:07 PM
jkeaton's Avatar
Factory service manual is not easy to follow but the wiring diagrams are in there, just scattered. It took me forever trying to figure out the brake wiring.
Old Nov 22, 2012 | 08:47 PM
I have been using GM diagrams for decades. I am not try fix something. I am putting together a car I did not take a part and I have never seen together. I want to get the harnesses routed as the factory intended.
Old Nov 22, 2012 | 08:54 PM
66fordman's Avatar
Can You track down a 93 in Your area? Maybe a hands on view would be better than a manual..Worth a try..
Old Nov 22, 2012 | 09:08 PM
Good idea. I will check out some local lots. 2 minutes a HD video from the engine compartment would have a lot of information.
Old Nov 22, 2012 | 09:41 PM
have you seen this 1995 Z28 A4 Engine Harness almost the same, i think the maf and auto trans are different.
Old Nov 22, 2012 | 10:17 PM
heres some pics i had handy
i have a vented opti
