93 Camaro Intake Manifold Vacuum Fitting? Shaped like a Y tube with 2 branches and a.
1 Attachment(s)
Hi, anyone know about the following...
1993 Camaro V-6 Base Intake Manifold Vacuum Fitting? Shaped like a Y tube with 2 branches and a...stem it's plastic and like you can stick your finger thru the holes it is for a 1993 Chevy Camaro Base v-6 Intake Manifold Vacuum Fitting" it's shaped like a Y and is connected to the intake manifold (it looks like the letter Y, but UNLIKE the attached photo it is Plastic and you can stick your finger thru it) if that part is missing / cracked when u start up the car the rpms go up reallly high and its noisy kind of scary like the motor will explode i have a head injury that prevents me from going on hghwy and driving to the junkyard let me know please, if u have this and I will gladly buy it from you for a profit to you, fellow member(s) many places have discountinued selling this little plastic piece that looks like the letter "Y" with a stem and 2 branches on each side. again it's for a 1993 chevy camaro v-6, not sure if the 92 to 94 ones are compatible also *that brings me to my other question is it just for a 1993 or is there a range 92-94 or up to '95 thanks, thanks a whole lot just for reading this. |
HERE is another link JEGS official sponsor of drag racing is selling one like the following. Autopart number that starts with 555..... but they all look the same black and plastic. It's really a "Y Fitting" which one do you all think fits a 93 chevy camaro base? JEGS One-Piece AN to AN Y-Fittings | JEGS Performance Products
i think your looking for the part # 10217828
HARNESS. Engine Crankcase for Chevrolet. #10217828 |
you may find what you need on ebay as well $10.50 shipped you for that part #10217828 craby gave you for whole harness an theres a picture to see ,an there plastic or rubber yours was dry rotted don't know that they make a metal one 93 3.4l v6 ,was made till 95 ,then late in 95 the went to the 3.8l, its the pcv vacuum harness ,you need to replace the whole thing cheap part
thanks to you both. I have ordered an attached one; no more plastic it seems,
1 Attachment(s)
my freelance mechanic will have to modify it he said to make it work with my car as the one sold on Ebay attached below which I purchased 1 day ago is threaded and made of steel, it's like the one in the attached photo they don't make plastic anymore but thank you to you both who took the time to reply after reading have a Happy Holiday season, if the one that comes in is not compatible, then I will definitely by the one Craby showed, that particular part # thanks again |
yes it must have been the way you searched couse all I came up with was the harness with the plastic one ,my guess if he is going to modifiy it ,its not for the car then ?,what ever works the other even plastic one was there for alot of years .my dad used to say everything is plastic now ,that was in the mid 80s
(Post 706700)
