6 spd. Question HELP
Old Mar 2, 2008 | 07:31 AM
sethscamaro01's Avatar
Default 6 spd. Question HELP
Whenever i go and put the transmission in reverse i have to hold it in or it will jump out and grind. I have to hold it in and ease off the clutch about a quarter until i hear it click in, whats going on here is this normal or something needs fixin. Please help me
Old Mar 2, 2008 | 01:51 PM
Default RE: 6 spd. Question HELP
bump???
Old Mar 2, 2008 | 01:57 PM
6v49der's Avatar
My 5-speed does that sometimes too. I was told that alot of manuals dont like reverse, but then again I dont know.
Old Mar 2, 2008 | 02:43 PM
baseballer91's Avatar
how high in the rpms are you in? thats happened to me when i tried shifting without payign attention and still be moving. ive also gotten thrown out of 1st.. haha not fun.
Old Mar 2, 2008 | 02:48 PM
it does it when im dead stopped and try to put it in reverse!
Old Mar 2, 2008 | 03:49 PM
do you push the clutch completely down?
Old Mar 2, 2008 | 04:51 PM
yep
Old Mar 2, 2008 | 04:56 PM
6v49der's Avatar
Does it ever not want to go in? Like when you go to put it into reverse it feels like there isnt even a gear there, and you have to double clutch it in or let the car roll a little so it can slide in? I dont know what that problem would be but thats something my car does sometimes and one of my friends Eclipses does.
Old Mar 4, 2008 | 07:20 PM
Bowtie4life's Avatar
ORIGINAL: sethscamaro01
my car does the same exact thing, really pisses me off cuz when it desides it doesn't want to go into gear it takes at least 2 or 3 tries, and it likes to do it when other people are around[:@]. I've heard that it can either be the lock out solenoid, or the synchro, yes the t-56 has a synchro for reverse. No definitive answer on how to really tell which it could be, or if could be something else. I really wish that we could get a answer from someone who's had this problem and has done a tranny rebuild and could report thier findings.
Old Mar 5, 2008 | 06:30 PM
deltav's Avatar
That would happen to me, but in second gear. It got worse and then it wouldn't go into second. I had the tranny rebuilt and found out I needed 1st to 2nd synchro assembly and a newsecond gear (this was on top of the rebuild kit I bought).
I also needed a new input shaft(which would explain the low grinding sound in 4th @ all rpms), and a new 5th-6th synchro assembly. The tranny had about 190k in it btw.
