5.3L LM7 swap
Old Aug 22, 2019 | 01:45 PM
Jeremy Muniz's Avatar
Default 5.3L LM7 swap
Has anybody done this swap? If so what oilpan did you use for crossmember clearance and ground clearence
Old Aug 22, 2019 | 05:46 PM
If you are swapping a LM7 into a LS1 car just use the LS1 parts because the LM7 is just a iron block LS motor. It is a direct fit. All non-LS1 4th gens would require a lot of work as they have different Kmemebrs (frame) and motor mount. We can get into details on that but no need until you tell use what you are working on.
Maro_Boy98
Jan 9, 2017 10:13 AM
John4649
82-92 V8 Tech
12
Nov 5, 2012 11:59 AM
pimparsons
Jul 23, 2009 03:17 PM
chevychick99
Nov 14, 2006 09:39 PM
JT
Aug 31, 2006 03:18 PM
