4th gen wiper blades - help.
Wife drives a '97 Firebird. She was under strict order to never have anything ever replaced on the car as that is strictly my area. Well, she OKed the tire shop to replace the wiper blades. The factory ones are gone and I've tried every aftermarket one I can find; nothing fits or cleans the whole windshield.
My GM dealer said GM no longer stocks replacements.
Help. Where can I find replacements that will fit AND clean the windshield? The darn thing curves too sharply for the standard junk, which fit the arm, to clean.
Was there ever a different arm that has the end curving in rather then out? That is what keeps the better after market blades from fitting.
Anybody have a parts car with originals and wouldn't mind selling me a set? Surely refills are available if I had a factory set of blades.
Sorry if this is already posted somewhere. I'm new to your forums and I couldn't find a 'search' any where.
Thanks,
Bill
Thanks,
Bill
hmm...i own a carquest store and have carquest wipers on my car and haven't had a problem...that's weird that you do...if you go to carquest and they have trico(that's the brand i sell) the number is 24-59R...you SHOULDN'T have a problem but if you do, sometimes you can try a shorter blade(shorter i mean like an inch) and it usually fixes the problem
Thanks for the suggestion whammer. I might have to go with a shorter blade as a plan B.
Still, just drives me nuts that the aftermarket and GM has left the 4th gen high and dry on this one.
Kind of hoping someone chims in and says that, '...X year 4th gen used a wiper arm that curves in (towards the windshield) instead of out...'
Just seems like a major engineering oversight on the part of GM. We love this car, just dislike the lack of a proper fitting and easy to find blade. I'll have to check with my local CarQuest. There is one in town.
Anybody else?? I'm open to all suggestions.
Had this issue with a bunch of blades - had to get the "R" blade that whammer mentioned. It still doesn't get all the salt spray off like I'd hoped, but it's "OK" for now. I'm hoping to tweak it a bit further.
I've never met a blade that didn't conform to the curve of the windshield. The spring tension on the wiper arms is what keeps the blades tight to the glass. But from your description it sounds like your arms are bent out, they should be bent in towards the windshield. Bending them in should take care of it.
