4l60e swaped to a 350 th
Old May 11, 2010 | 02:12 AM
scfaust's Avatar
Default 4l60e swaped to a 350 th
id like to know if i can swap my 4l60e for a 350th i have in my garage and if i can what would i need to do like cables drive shift and mods at all it in a 94 z 28 or could i just bolt it inand go with no mods
Old May 11, 2010 | 07:24 AM
No, Mount, Crossmember, shift linkage and drive shaft will all need mode You will also have to add on Very long shift cable. The biggest problem will be the computer. When the computer can not find the the tranny it will light up. Also you gas milage would go from not to bad to complete crap on the highway.
Old May 11, 2010 | 11:02 AM
sell the 350 and use the money to have the 4l60e built.
Old May 11, 2010 | 11:49 AM
scfaust's Avatar
ive tried thati have 2 350 a posi rear end and a 383 stroker, with 2 79 cutlass' but noone seems to want to buy any thang right now. amd i cant seem to find the trany the junk yard tels me it has to be out of a 94 or 95 thats it and camaro or firebird thats it true or not??
Old May 11, 2010 | 11:53 AM
scfaust's Avatar
ive never doen a rebiuld is it hard
Old May 11, 2010 | 12:31 PM
for someone untrained with out the proper tools yes it would be very hard.
Since the transmission is controled by the computer and there was major computer upgrade in 96 i would think the junkyard is correct.
Old May 11, 2010 | 01:57 PM
on the 94-95 to the 96+ the plugins are different. i think the vss may also be different. u can get a tranny ecu but they cost almost as much as a rebuild would cost. heres a couple tranny places to check out.
http://www.transmissioncenter.net/highperflist.htm
http://www.700r4l60e.com/
mikew
Mar 19, 2010 06:35 PM
appel_1978
LS Series Tech
16
Feb 16, 2010 02:36 PM
User Name
Feb 3, 2010 08:04 AM
DMateo
Dec 8, 2008 03:36 PM
dodge destroyer
Mar 28, 2008 07:37 PM
