3.73 Differential Build
Old Dec 13, 2009 | 09:36 AM
User Name's Avatar
Default 3.73 Differential Build
Hello everyone,
I have a 95 Camaro Z28 and, would like some information about "beefing" up my differential from the stock 3.42 to a 3.73. I have talked a couple of friends and they highly recommend I just buy a 3.73, instead of tearing it apart and rebuilding it up because, you have to have every little measurements just right. I would like a walk through on how to do everything if its possible. However, any help at all would be greatly appreciated.
Old Dec 13, 2009 | 09:55 AM
maudyZ28's Avatar
i have an auburn installation document as a pdf , i could send it to you if you like?
also if you are getting new gears you stilll have to tear it all to pieces anyway, most people say not to spend too much money on a 10 bolt ( assuming its still stock) as they will eventually fail
Old Dec 13, 2009 | 07:55 PM
if u are planning to build the motor less than 350hp find a newer ls rearend (a little heavier built) and do the change of brakes while your at it.
Old Dec 13, 2009 | 09:57 PM
User Name's Avatar
Maudy, If you don't mind sending it, I'll take it. Thanks. Also, are you trying to say convert it to a Ford 9"?
Craby, My engine build is a 475 RWHP LT1. Thanks for the tip however, I need the stiffer differential to handle those horses. As for the brakes, I'm going with Baer set-up.
Old Dec 13, 2009 | 10:00 PM
then u will want either a 9 in or a 12 bolt. a 10 bolt will not handle that kind of hp. u have an auto?
Old Dec 14, 2009 | 09:02 AM
User Name's Avatar
Craby, a lot of people are telling me I need to switch to the Ford 9" but, I'll just see how the 3.73 works. Also, I do have a auto.
Old Dec 14, 2009 | 04:37 PM
yah im figuring on waitin for mine to blow before i change it but am not sure i can wait. lol.
mlopezart
Feb 24, 2012 12:20 PM
sikorski
Mar 12, 2010 07:11 PM
msharp1085
Feb 26, 2009 10:35 PM
oakwood69
Jul 15, 2008 11:28 PM
shnormo
Oct 17, 2006 02:52 PM
