3.4l stutter/hesitation when air is on
Old Sep 5, 2013 | 10:27 PM
v64thgen's Avatar
Default 3.4l stutter/hesitation when air is on
Like the title says, my 3.4 has had a stutter/hesitation under a load only with the ac on. The plugs have about 25-30,000 miles on them, they are acdelco rapid fire, wires were replaced at the same time, also acdelco. Just recently had the fuel pump replaced, also a new filter. The coil packs are 2-3 years old.
When the ac is off the engine runs smooth and strong, but when the air is on at times it has a hard time getting out of it's own way...other time it runs fine.....any ideas what is wrong? 231,000 miles are on the engine.
Old Sep 7, 2013 | 06:35 PM
v64thgen's Avatar
Hmmm, guess not.
Old Sep 8, 2013 | 11:34 AM
Most automobile AC systems use air doors which are controlled and operated by vacuum. May want to check for vacuum leaks when the AC is on, as the leaks could cause the engine to run poorly. A vacuum gauge connecter to the intake manifold would be helpful in trouble shooting.
Old Sep 8, 2013 | 06:06 PM
v64thgen's Avatar
Thanks, I'll look into that. I never even thought of that...obviously.
JGuy07
Jan 25, 2012 06:57 PM
hb22man
May 8, 2010 12:35 PM
BigRegUK
Sep 7, 2009 03:28 PM
95Z6speed
Mar 10, 2009 04:44 PM
73camaroSS
May 14, 2008 08:44 PM
