2001 Camaro turn signal
First off I want to say Hi as I am new to this forum.
I have a 2001 Camaro and the right turn signal will not blink the light just stays on, but the let side works fine.
Could it be the turn signal relay or faulty wiring? The bulb is fine.
Any suggestions or input would be greatly appreciated.
Thanks
Thanks
if any of the blinker bulbs for that side are burnt out then it won't blink. also if there is a break in the wires or bulb is not connecting in the socket. if your going to replace the flasher make sure you do the blinker flasher and not the 4way flasher. also use a electronic flasher in case you want to switch to led, more reliable too.
Check for corrosion in the sockets. My rear bulbs had lots until I put some drain holes in the lenses. My passenger front bulb likes to back out of the socket too. Probably from the plush ride.
Also, does the rear bulb stay on or not light at all? Could be lots of things...grounds, sockets, bulbs.
