1st fbody needs help
I have a random issue. Kind of a buck or cutout that finally set ses light. found a vac leak, now its not as bad but still there. oh by the way its a 93 rs. When I do the jumper for the codes, the fan comes on and ses light illuminates but never flashes.
solid light may be a icu problem. stop by the local parts store and see if they have a obd1 scanner that they will hook up for you or let you do it. also see if they have a code reader you could run out and see if it works. without the codes it could turn into a very expensive turkey shoot trying to find issue/s by replacing everything.
have tried 2 different ecu both used. both ses lights solid no flash, one I put in today doesn't stumble as much. gonna change fuel filter tomorrow. it only does it if you take off hard or at highway speeds.dont know bout the ses though.
