1998 v6/5 speed with mouse problem.
Old Jan 16, 2025 | 10:29 AM
Mloncarich's Avatar
Default 1998 v6/5 speed with mouse problem.
I recently acquired a 1998 v6/5 speed that has sat for 12 years. Mice chewed several wires, plug wires, etc. I repaired all of the wiring except the small red wire to the alternator, which was chewed off at the connector at the alternator and I can't find the other end. It is a 4 pin connector, but only uses 1 wire. 99 and up are different. If someone could send me a pic of where that wire comes out of the harness I would appreciate it. Thanx
Old Jan 16, 2025 | 09:20 PM
that's the exciter wire at least that's what I call it. when you turn on the ignition it puts a 12 volt signal to the alternator that lets it know its time to work.
dooapboi
Oct 18, 2014 07:38 AM
BLK79
Aug 3, 2012 03:56 PM
CamaroBeast98
LS Series Tech
May 12, 2009 02:38 PM
sidewayz28
Jan 6, 2009 10:07 AM
pyrofire127
Mar 6, 2008 11:57 PM
