1996 3.8l running hot
what should this car run at as far as temp? my temp gauge goes pretty close to 280 at times..other times it will run right in the middle..had water pump replaced due to leakage still doing it..maybe change out the t-stat..had coolant flushed as well..
it dosnt run that high all the time..its just random..it did it before the water pump was put on as well..just wondering if i got a sticky t-stat
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
