pcarollo |
03-14-2017 09:04 AM |
1995 Z28 Distributor
Ok fellas, talk to me about the distributor on my 1995 Z28. She's got 104k on her and is running rough. Head gasket changed recently and idle was rough, ignition coil was bad and changed and it has since run better, but it's still not quite right. Mechanic thinks it's the distributor. I had a leaking water pump last summer that was changed, but didn't have any change in the idle.
So tell me, when the distributor is going out what are the symptoms?
Thanks!
