1994 z28, what should i be running?
Old 01-26-2008, 12:38 PM
aleksandr's Avatar
Default RE: 1994 z28, what should i be running?
With a good converter and a shift kit, autos can get significantly faster than the stock 6-speeds from a dig.
Old 01-26-2008, 04:49 PM
Spartan66's Avatar
werd.
Old 02-19-2008, 09:13 PM
mattz28red's Avatar
bump
Old 02-20-2008, 12:30 AM
95slvrZ28's Avatar
Why did this deserve a bump? Low 14's stock, a well built auto is faster than a manual because humans can't shift as fast as a machine, and you can get off the line better with an auto, and a 1/4 mile run is usually made in the first 60'. That's about the end of the story...
Old 02-20-2008, 03:06 AM
tspence45's Avatar
With headers, intake, exhaust, and a tune,I'd say you could probably muster up a mid-13 as long as you could get the launch down.
Old 02-20-2008, 03:27 AM
SixShooterCamaro's Avatar
Why dont you take it to the track and find out?
Old 02-20-2008, 11:19 AM
importmd's Avatar
I would think stock for stock the stick would be faster in the 1/4. you cant launch a auto like you can with a stick, unless you like to do neutral drops, ouch.
Old 02-20-2008, 02:19 PM
95slvrZ28's Avatar
Attempting to "launch" our cars usually generates tire smoke. My car broke the tires loose all through 1st gear when I tried to lauch from 2200 RPM with my A4. Stock for stock the times between the A4 and the M6 are about the same. The A4 actually has a more aggressive 1st gear even when you take in the diffence in the final gear (3.23 for auto, 3.42 for manual), and like I said before, the A4 shifts faster than the M6. The benefit off the launch is you can't bog an auto, you hit the gas and go.
Old 02-20-2008, 02:29 PM
SpecterGT260's Avatar
Ninja Administrator
you also cant powershift an auto. To really make the auto perform you need to increase the shift firmness
OP ill give you a mid-high 13 if you get a good launch
  #20
Old 02-20-2008, 03:03 PM
STIC5's Avatar
I agree with Specter's estimate. That car should be running in the 13's unless it's just worn out. My car is very similar and I haven't taken it to the track yet. I need to get on that...
Quick Reply: 1994 z28, what should i be running?
