1994 Camaro v6 headlights wont turn on
Old May 12, 2013 | 01:36 PM
camarobub's Avatar
Default 1994 Camaro v6 headlights wont turn on
I just got this 1994 camaro v6 but the headlights wont turn on. The rear end lights work and the running lights work. The button turns on. I checked the fuses but there is no spot for the headlights. I checked to see if the fuseable links were messed up but they seem good. Any ideas I need some help
Old May 12, 2013 | 04:41 PM
headlights may be burnt out. test to see if 12 volts are getting to the light. if not track back to the headlight switch and see if your getting volts there. headlights have a fuseable link somewhere and if thats failing you wont get power to the switch, its a red wire to the headlight switch
Old May 15, 2013 | 04:46 PM
camarobub's Avatar
The switch has power and the lights do not where is the relay located for the headlights?
Old May 15, 2013 | 05:00 PM
when you turn the lights on is there power going out from the switch. look at 43 here 4th Gen LT1 F-Body Tech Aids the rap has the headlight relay in it.
Old May 17, 2013 | 06:55 PM
camarobub's Avatar
cad
Jan 31, 2013 02:44 PM
hoot79714
Oct 22, 2011 08:37 AM
wazowski
Aug 11, 2011 10:18 PM
gld7
Feb 6, 2011 07:04 PM
hb22man
May 5, 2010 10:24 AM
