1993 ~ 2002 Camaro Door Handle Broken/Disconnected
Old 04-12-2015, 06:10 PM
JonnyCam's Avatar
Default 1993 ~ 2002 Camaro Door Handle Broken/Disconnected
I closed the door on Cammie today and noticed the outside door handle felt VERY loose. I think it had already felt a little loose if unlocked but now it felt totally disconnected, which, in fact, it was. Even unlocked it won't budge the door latch at all. My guess is that it's a very mechanical connection and will be very obvious once I get the door panel removed. Is there a good description (photos & step-by-step) on removing the interior door panel? Any guess what happened or just time loosening "something"? The interior handle seems to work (thank goodness or she'd be unusable).
I saw this post which looks similar but appears to not have a good response yet. link
Brand New to the Forum and hoping I can find value & be of service. Any repairs I make you'll get good photos and descriptions (plus good SEO know-how).
Last edited by JonnyCam; 04-12-2015 at 08:45 PM. Reason: Determined to use Cammie instead of Cammy
Old 04-12-2015, 11:48 PM
go here and click the first one, firebird nation https://camaroforums.com/forum/93-02...92/#post567086 it has a pretty good detail on the door panel removal
Old 04-13-2015, 07:57 AM
JonnyCam's Avatar
The fifth one (youtube video) does a "decent" job also. Wish I could see the actual connection (mechanism to the handle) in one of these. I'm hoping it's something disconnected and not broken, guess there is only one way to know...
Old 04-13-2015, 09:53 AM
my outside handle broke so i had to replace it. not fun so much so that i can't remember doing it. lol.
Old 04-19-2015, 05:38 PM
JonnyCam's Avatar
This one (Adjust Door Window) had some good images and directions. Turns out a little plastic (!!) connector which holds a metal door latch control rod to the handle broke. Temporarily I have a rubber band in there but I don't think a "Broccoli stalk collection unit" band will be a good long term solution to this.
I'm doubting I'll be able to find that part so I may need to devise something else to prevent the rod from sliding off the handle. Be great if they had used a threaded rod and a nut but that sounds too easy and permanent. Wanna bet GM can't get that part any more? I'll be surprised if they can but maybe it's something used on lots of cards in which case there may be hope. Even if I can get it, might be better off engineering something more permanent. I just hope when all is said and done that the door panel goes back on as well as when I removed it. (definitely and art to that maneuver).
Old 04-20-2015, 04:41 AM
trying to figure out how you got a rubber band in there,,,,
Old 04-20-2015, 04:58 AM
Old 04-20-2015, 04:59 AM
Old 04-20-2015, 06:56 AM
JonnyCam's Avatar
It's official then, you're my hero! (love having gurus in this world). Once the door panel was off it was only mildly "contortionist" to get a rubber band in there and wrap it, (and then wrap it again and again about 8 times until it felt tight). Glad GM provided enough of an access area to reach up there. Normally they seem to design things so that once the car is out of warranty repairs are impossible. I was hoping the absence of such a clip wouldn't mean my car was totaled. Thanks Craby!
Found them on RockAuto.com too 15 Pack for $7.80!! (first saw ¢.52 ea and got pretty stoked) Sadly that's either left or right side but I guess if I go that way I'm covered for life. (Dorman part though, not GM - hmmmm)
Then I thought, call the Buick dealer around the corner and BINGO - $2.00 in stock! (last one on the shelf).
So decided to enhance the product part photo, was so washed out, hard to see but now I see the part, what broke off and how it works.
Door panel removed
Inside the view hole (on top photo has some gray primer around it, good for viewing the latch area) - Just reached up with the band and started twisting it on there but I want to get a real fix in there asap and re-assemble the door panel. Good project for me. I'll see if I can get a photo in there of the rigged fix before I get the replacement part in there.
Thanks again for finding that part, I wasn't even sure what to look for or where to start.
Last edited by JonnyCam; 04-20-2015 at 07:22 AM. Reason: added images and more detailed information.
Old 04-21-2015, 07:58 PM
JonnyCam's Avatar
Default In Conclusion
Definitely a winner here, found the official GM replacement part at a Buick Dealer around the corner for $2. (un-officially the least expensive part sold by a dealership ever, anywhere**)
My previous rubber band solution was working fine but no telling when the band would wear out and I'd embarrassingly need to admit the truth that older cars do this thing I call "falling apart for no reason" - craby, you asked, here 'tis.
Next step (for anyone who needs to do this) is note that you have to put the plastic retainer through the hole before placing the rod into the retainer. Otherwise the clip won't compress (which is why it won't fall out after you assemble it)
Then insert the horizontal bend of the rod (a little contortion here but not too bad)
and flip the retainer down so it snugly holds the vertical part of the rod. If we need to show you that, you probably didn't successfully remove the door panel.
Special cautions then: Taking the door hardware apart and re-assembling it was the most challenging part to me. Really felt like something might "snap" but I was very gentle and careful and the "Chevy Gods" loved on me today so nothing broke. That said, actually the clip inside of the panel which holds the switch illumination lamp did crack. A little super-glue worked to repair it but be careful with that. Getting the door lock slider cover back on was one of the more time-consuming aspects, gentle persistence lavishly applied. The whole thing probably took me 45~60 minutes or less mostly from not knowing what I'm doing. Could probably be a 25 minute job if you're good.
One more thing, I'm going to add a photo as there was one part (like the missing sock our wives deal with) that was left over after the door was re-assembled. Some type of little metal clip. I'll add a photo of that soon to see who knows what that might be and why I may need to care. Thanks for all your Help Craby! (You da Man!)
Quick Reply: 1993 ~ 2002 Camaro Door Handle Broken/Disconnected
