1993 Camaro Z28. idle issue
Old 08-09-2016, 01:17 PM
yes i like to think of it as clearing all the little computers in the system.
Old 08-09-2016, 01:20 PM
i had a lean condition on one side and it was a failing injector. had them cleaned and flow tested, replaced two bad ones and cleaned the rest, good as new.
Old 08-09-2016, 02:10 PM
Bigt21's Avatar
Originally Posted by craby
first off try doing a full system reset. take both battery cables off the battery and hold them together for a minute,,, well 20 seconds anyways. this should reset all your systems. they will have to re learn so it will run funny for a few runs while it re learns how to adjust everything. it will also clear all your codes so you will not be seeing any old codes but it will reset codes that are still present. also if you have any capacitors or a backup battery you will want to disconnect. it should clear your radio settings as well.
should i do this before or after replacing the o2 sensor?
Old 08-09-2016, 02:26 PM
no reason not to. go for it. lol.
Camaroforlife
08-08-2013 08:14 PM
grabbem88
08-29-2011 07:03 AM
mtm
09-07-2010 07:17 PM
sl1foru
10-21-2007 05:30 PM
Quick Reply: 1993 Camaro Z28. idle issue
